Pie in Edson pedestal
Posted: Mon Nov 16, 2020 12:12 pm
by NormSail350
Hi everyone,
I am having my shift cable replaced. I am going to have a marina do this, and they are suggesting adding a pie eye access port in the front (bow side) of the pedestal for access. Seems like a good idea. I have not looked inside the pedsetal (at least not with this soecific idea in mind).
Has any one done this? Seems to make sense as long as nothing else is in the way or would be bothered - since my boat is a 2003 and things need to be replaced (i.e., I will also replece my ignition switch soon).
Any thoughts/concerns?
NormSail350
2003 Escape Hull#41
Re: Pie in Edson pedestal
Posted: Tue Nov 24, 2020 6:17 am
by Alessandro
Hi,
About 2 years ago I cut an approx. 4" access hole in my pedestal to fit an autopilot assembly. It all worked out very well, from memory there was nothing at risk around my cuts. In my case the hole was cut about a foot off the deck on the stern side, i.e. forward of the wheel.
Posted: Tue Nov 24, 2020 10:13 am
by NormSail350
Alessandro,
Thanks for the reply. I am opeining the pedestal today to look and to explore options and whether its a good idea and will share what happens.
NormSail350
Escape Hull #41
Palmetto Bay FL
