Furuno First Watch
Posted: Thu Nov 14, 2019 7:04 pm
I spent ages looking at options when adding a radar. I did not want to go the route of upgrading all the ST60 Raymarine system and seriously considered a second hand E80 display with a new Raymarine radar and also a multitude of other manufacturers options.
In the end I went with buying a Furuno First Watch Wifi radar and a new ipad. I also spent some time looking at where and how to mount the radar and went for the Garhuer solution of a 7ft radar pole connected at two points to the port side of the pushpit stainless with a single bracing strut to the hull (the owner of Garhuer has 350 hull #1 in Marina Del Rey Ca and I went and had a look at his setup).
It was easy to drill a single transom hole for the wires and put a clamshell cover over the hole and run the wires to the panel.
Just got back from a trip to Mexico, it all worked really well, the ipad solution means you can sit anywhere in the boat and have a radar screen with you. Very happy with the radar, mounting and ipad.
