Raymarine C80 NMEA port
Posted: Sat May 18, 2019 1:34 pm
by elk
I'm upgrading to a Raymarine Axiom 9 chartplotter and wondering what the NMEA port on the C80 is used for, do I need to transfer that cable to the Axiom somehow? I don't have any NMEA device that I'm aware of, no AIS, etc.
Thanks for any forthcoming info.
Re: Raymarine C80 NMEA port
Posted: Fri Feb 19, 2021 2:38 pm
by c350ia
Most commonly used for AIS so that it displays on your MFD. Assuming that your AIS is not a Raymarine model which would communicate via SeaTalk or SeaTalk NG. Could also be used by autopilot, again assuming that you had a non Raymarine autopilot.
Posted: Sun Feb 28, 2021 6:27 am
by sgoldman
Hi, new to the forum and C350. I’m looking into replacing my C80 with an Axiom 9 as well. The boat is still pending close So I can’t look closely.
Is the cabling used for the C80 Seatalk ng or is it Seatalk 1?
Posted: Sun Feb 28, 2021 3:08 pm
by Captain Kirk
Hello
Looking at a picture of a C80 I found on-line, it has the 3 pin connector for SeaTalk 1 on the back. So you will need the ST1 to STng converter.
