Reposting a shaft question
Posted: Tue Feb 28, 2017 7:43 pm
Apologies for the repost. I didn't see it in the emailed digest, and there were no responses, so I figured what the hell
How much prop shaft play do others have at the transmission side. Uncoupled, that is.
I've no play at all at the cutlass bearing, but quite a bit where the shaft enters the stern tube in the boat.
Associated question - my pss seal is not water cooled, nor is my hurth transmission for that matter. Should either or both of those things be spring projects?
Thanks as always
Thanks as always
