Top down spinnaker
Posted: Tue Oct 25, 2016 3:40 am
by Wisail
I have 2010 hull number 489 and want to install a top down furling spinnaker/code 0. The twin anchor rollers take up a lot of space where a pole could go. Has anyone fitted a extendable pole with this roller set up? I thought about making some delrin guides that fit into one of the rollers and installing an attachment in the locker as I only use one anchor. The pole would conflict with the shank of the anchor. There is a loop on the end of the roller. Has anyone used this as an attachment? I would prefer more extension than this loop would supply. Thoughts?
Re: Top down spinnaker
Posted: Wed Oct 26, 2016 5:53 am
by markws1852
I have hull number 300 and installed a top down code 0 last year. We did not install a pole but instead used the port side anchor roller to install the furlex code 0. My yard fashioned a loop that goes around the bow roller and attaches to the bottom of the furlex drum. Works fine with a couple of cavets: (1) you cannot tack without furling the sail. This has not presented a problem so far as we tend to use the spinnaker on long tracks; (2) it is a bit more cumbersome to raise the spinnaker at sea with this configuration. We tend to do it at the dock in preparation for its use during our sail. Once furled, it does not interfere with the use of our jib.
Mark
Legal Tender III
Posted: Fri Nov 04, 2016 12:21 pm
We attach our furling spinnaker directly to the loop over the port anchor roller. You may want to read this thread with pictures of various configurations.
viewtopic.php?f=17&t=791
