Replacement Upgraded System - Which did You Choose?
ChuteUp
Post by ChuteUp »
After reading so many Fridge Threads with unhappy owners & acknowledging it's more than one thing (Insulation, Door gaskets, etc count too)
For those (especially in much warmer / hot climates) who chose to Upgrade / Expand / Re-configure their Fridge System, could you please share your System components.
In the meantime, will continue reading through old threads trying to learn & extract all (there are many) the valuable suggestions, hints, lessons learned ....
Thanks in advance. 8)
Re: Replacement Upgraded System - Which did You Choose?
I added insulation to my system and was able to significantly decrease the compressor run time. I followed the method used by Jim Gienko. The link to his write up is in the first post of this thread - viewtopic.php?f=16&t=396. It is a Word document with pictures detailing each step. The only thing i gave up on were the recirculating fans that he recommended. They were a bit of a pain and I didn't feel that they made that much difference.
ChuteUp
Post by ChuteUp »
Thanks for the response & the link.
Sorting thru all the suggestions, new info & alternatives/options to put into action when the opportunity arises.
Thanks again 8)
