Given the space (factory), the VD-150 & VD-151 Adler Barbour Evaporators are the only choices.
The 150 has the built in Ice Tray arrangement which is not preferred.
The 151 would work BUT all the written notes on websites / Brochures label it a Horizontal Unit which is somewhat understandable since a Door usually is lifted or dropped to access a freezer compartment. However, it should work mounted Vertically with the door opening toward the back wall of the compartment. Maybe the door could even be removed.
Has anyone installed or seen a VD-151 installed Vertically? Any Technical sources to access??
Adler Barbour Spec Sheet
http://www.dometic.com/QBankFiles3/EPiS ... _24494.pdf
Thanks in advance for assistance
P.S. Just to clarify.........realized that really want to mount the Evaporator on it's side - so the food, ice would be accessed for the side of the unit. Yes, will need room for door to open toward back wall to allow access to inside Evaporator.
Horizontal would have front access & vertical would have top access.......old unit has side access due to space limitations
