Page 2 of 2
Re: Sump Pump In Shower
Posted: Wed Nov 04, 2026 9:20 am
by nybor
it is the $24 one on Amazon. But I haven't installed it yet. Just took the measurements for fit. However, I am debating about getting the non-auto one instead and hook it up to the existing paddle float switch. You can hook this one up to it as well, but it is shorter. If you can wait a day or two, I will install mine (the auto one) and report back.
SEAFLO 06 Series Automatic Submersible Bilge Pump - 750GPH, 12V, 3/4" Outlet, 4-Year Warranty! - All-in-One Pump and Float Switch, Snap-Off Strainer, Compact Marine Boat Yacht Bilge Pump
Posted: Wed Nov 04, 2026 9:22 am
by ElizabethG
Thanks Dave!
Posted: Thu Nov 12, 2026 1:12 pm
by nybor
) #$Q%&Q#%& Ok, I have calmed down.
I replaced my shower pump and wrote a lengthy procedure on how to do it, but can't find it now????
Anyway, here are two photos showing the main things I had to access to get it in.'
Found my thesis!
SUCCESS!!!!!!!
However, 350 owners know by now, that there is a big BUT.
I took some photos of how to access the drain. I don't see here. Maybe I need to go to the main forum location to add them.
But here is a step by step method.
1. remove the sink door! Also, later in the instructions, the easiest way to get access to the hoses beneath the sink is to put a towel or cushion on the lip of the vanity, put your legs out facing and into the forward cabin and squirm in on your back.
2. make sure the 19 mm I.D.(the one already installed - also labelled as a 3/4" I.D. Trident potable water hose) hose attached to the anti-siphon valve is closed! That is why you remove the door, It gets in the way big time later on.
3. Pop off the red top of the installed pump.
4. My 2006 boat's pump had its 1/2" plastic nipple broken off from the pump housing so it leaked. it also came out.
5. There are two screws that hold down the blue strainer piece of the pump to the bottom of the shower floor. Remove and out comes the old pump.
6. Mine was not attached to the hose. But once I look at the end of the hose I saw a small plastic inserted into the 3/4" hose to make the connection to the 1/2" pump's nipple.
7. I couldn't pull it out and in fact it slipped down further into the 3/4" line!!!) #%&)#%&#Q&. If you can pull yours out great. I am going to replace the hose anyway so don't care at the moment.
7. NEXT - Important. The way to get the pump into the space I needed to pull the 2" hose sticking out of the pumps wall enough to hook up the pump and THEN stick it back down. In order to get it out far enough, if you remove the 4 screws that hold the twin hoses attached to the anti-siphon part to the wall (under the sink) then the three little screws holding the plastic anti-siphon to the wall, you can bring it out which will allow you to then push the two hoses down while pulling the one that is connected to the shower/pump out enough to connect the new pump to the 3/4" hose (without the insert). It fits perfectly once you pull the twin hoses back up and reattach them to the wall.
Posted: Thu Nov 12, 2026 1:27 pm
by ElizabethG
Thanks Dave,
I just placed my order, with Amazon, for the same unit!
