Damper Plate Replacement Notes / Procedure
Post by ElizabethG »
Hi Gang,
There have been several posts on the damper plate replacement over the years.
Jerry Ross put this out back in 2012; http://www.catalina350.com/phpBB3/viewt ... f=11&t=685
Does anyone have additional notes, instructions, procedures, hacks they can share?
I may attempt to do the replacement, or have a good set of notes to hand to a mechanic if I go that route.
Also, there were several recommendations on which plate to order ranging from a few hundred dollars to $1.5K. Any recommendations from those that have done the replacement?
Re: Damper Plate Replacement Notes / Procedure
Post by Olivia Mae »
No notes, but the R&D high deflection damper sold by PYI worked well for us. Have about 800 hours on the new one since I put it in.
Thanks Scott & Linda!
