Water Supply Valve
Greg_D
Water Supply Valve
Post by Greg_D »
Does anyone have a source of supply and/or a part number for the water supply valves from the water tanks?
They are located under the sink in the galley.
johnthejetpilot
Re: Water Supply Valve
Post by johnthejetpilot »
Hello Greg. Have you checked with Catalina Direct? (916) 379-5882
Jillian cd1@catalinadirect.com
or Kent cd2@catalinadirect.com
If no luck- I suggest Warren Pandy at Catalina. He’s the Yoda for all things Catalina- warren@catalinayachts.com
Happy hunting!
John
Ave Maria
Hull 212
Kenosha, WI
elk
Post by elk »
I replaced one of mine a couple years ago, easy job. Got the valve from Ace Hardware online and picked it up at my local Ace. Price was very reasonable so I got 2 and used 1 and 1 spare. Same exact valve and easy swap. I have the spare in hand and it is a Zurn Qest 3/8" x 3/8" globe valve. Yes QEST.
All I did was remove the handle by unscrewing the large hex fitting just below the handle. Swapped it out for the new one and never had to remove the valve body.
Ed
Ed Kruzel
S/V Emily
Hull #399, 2006 C350
Cataumet, MA
