LED anchor light
belladonna
Re: LED anchor light
I have a 2005 C350 #368 and wish to replace my anchor light bulb with an LED bulb. Does anyone know the brand (Hella, Imtra, etc.) of the actual fixture and bulb that came with the boat from the factory?
Thanx,
Jim
Thanx,
Jim
Jim Lassiter
Hi Jim,
I replaced mine years ago with this one; https://www.doctorled.com/store/nav-LED ... H2492-Star
C350, #193
C350, #193
Mark Sutherland
This is the deck light I have on my boat, which may not be the original, but it works very well. https://store.marinebeam.com/5w-mr16-de ... r-mr16-5w/
Mark Sutherland,
Dunrobin III
Hull #388 (2006)
Dunrobin III
Hull #388 (2006)
belladonna
Thanx for your response Bill and Mark but I was asking for the brand of the fixture atop the mast, not the replacement bulb type. I already have the bulb information from your previous posts.
Thanx,
Jim
Thanx,
Jim
Jim Lassiter
yodagwb
I tried replacing the original bulb with a LED several times with the same results. At first it was fine and then over time it would get increasingly dim. I finally gave up and replaced the whole anchor light assembly with a LED unit. No problems.
yodagwb
belladonna
Thanx for your reply 'yodagwb'. What brand of LED anchor light assembly did you replace it with? What year is your C-350, mine is a 2005 # 368?
Just want to ensure that the original anchor light assemblies are the same.
Thanx,
Jim
Thanx,
Jim
Jim Lassiter
