Thread sealant/lube
c350ia
Thread sealant/lube
Post by c350ia »
I am in the process of replacing the rinky dink jam cleat for the main sheet. Going to upgrade to a Spinlock identical to the other Rope clutches. When I pulled the machine screws I noticed that there is some form of grease or sealant on the threads and it certainly did a good job. Trevi is a 2008 and there was no corrosion on the machine screw and it did
Anyone know what this substance is, it clearly does not harden or form into an adhesive.
Re: Thread sealant/lube
If you are looking for something to materially reduce corrosion between two dissimilar metals TUF-GEL is excellent. Have used it for decades for stainless steel bolts into aluminum mast.
But, it has no sealing properties/will not keep water out. You may need both a small amount of polysulfide sealant as a bedding compound and the Tuf-Gel further down on the threads themselves.
Here’s a rather long, detailed “how to” that shows the best way to bed deck hardware using butyl tape - https://marinehowto.com/bed-it-tape/
KenKrawford wrote: Sat Apr 30, 2022 2:50 pm Here’s a rather long, detailed “how to” that shows the best way to bed deck hardware using butyl tape - https://marinehowto.com/bed-it-tape/
Yes, a good option and some interesting observations.
c350ia
Post by c350ia »
Thanks all for the responses. Tug Gel was the name that I could not recall.
D&M
Post by D&M »
That’s Tef Gel after all the auto corrects are fixed. :D
Regards,
David
Sea Lanes #281
Cairns, Australi
a
