I recently installed a VP-64 16x10 three blade prop. The prop came pre-set pitch at 10deg but this seems to be under powered in forward as I struggle to make 6kt thru the water at max rpm. The engine M35B does not appear to be laboring at all. Any advise on increasing the pitch in forward?
Alan Bray
Divine Grace #307
VP-64 variprofile 3 blade prop
dedgell
Re: VP-64 variprofile 3 blade prop
I installed a VariProfile 2 seasons ago. I purchased from AB Marine. They suggested, and I purchased, a 15X10. I wrote a detailed thread about the experience - I think its titled “Varipofile Prop” if you want to read. Long story short, I am very happy with it as set up and have not adjusted the pitch. I now cruise at around 6kts in most conditions, and max speed is closer to 7. I suspect that the extra inch of diameter may have something to do with your performance. I don’t know enough about adjusting the pitch to advise you.
Where did you purchase the prop? Perhaps call them and ask their advice on pitch.
David Edgell
S/v Blue Wing
C350 #442
David Edgell
S/v Blue Wing
C350 #442
sv.divine.grace
I also purchased from AB Marine and that was their recommendation.
Regards,
Alan
Regards,
Alan
