Raymarine Autopilot
Raymarine Autopilot
Hi.
Has anyone had the autopilot's screen say "No Pilot". I had a tech look at the system and didn't know what was going on. (Even though his company says Raymarine service repair.........)
ps as an aside, anyone in Sarasota who knows of a knowledgeable company re: Raymarine systems?
KevinMc
Re: Raymarine Autopilot
On the B&G "No pilot" means there isn't an autopilot connected. I've seen the "no pilot" alarm in two modes; (1) I haven't turned on the autopilot, (2) the display unit isn't seeng the autopilot when it's turned on. In my case I had to replace the faulty display unit.
Thanks. I have checked power etc.
I do have a strange question though. Where is the fluxgate compass located? It is a 2006 350 (#411). The reason is the autopilot was working - didn't try using it for a couple of months, installed an ultrasonic barnacle plaster system (3modules) on the hull and now the autopilot says "No Pilot". I wonder if there is a connection or electro-magnetic interference if the compass is near the transducer. I did try turning the blaster system off, but if the transducers have a large permanent magnet........turning off wouldn't help.
I would like to update my ST6002 stuff with something from this century. Had to replace the depth/speed module with the i7000 (I think it is 7000) last year, so it is a start.
anybody done this? (stupid question, since Leigh has for sure!)
Flagmanmike
I have the same question, so I called Catalina in Largo FL. They suggested looking under the aft berth mattresses. I haven't done that yet, but plan to soon.
Mike Cronin
Hull 314, FlagShip
Mike Cronin
Hull 314, FlagShip
Capt. Nini
The installation manual for the PD 500 Flux gate compass dictates the installation location should be: 1. On boat centerline 2. As far away from ferris material as possible 3. As close to the center of gravity as possible 4. Away from vibration.
I would look in the forward berth under the bed port side cabinet.
Dave and all who seek the holy flux-gate grail ,
Mine is located on the aft bulkhead in the port locker under the the counter top in the aft cabin. I found it when i stored a vacuum cleaner in that locker and the auto pilot stopped working and gave lots of errors.
After removing the vacuum and other can goods, I had to re swing the compass following the instructions in the set-up for the auto pilot. all is now well.
Happy hunting.
Happy hunting.
Aussie Mate
Mine, hull #357, is in aft cabin, port side, lower cabinet on the aft wall.
Bruce Whyte
s/v Aussie Mate
C350 #357
s/v Aussie Mate
C350 #357
Thanks folks. Of course, as soon as I posted the query, I remembered I saw it hidden in the port aft lower locker (say that fast 10 times).
But, nice to know there are 350 sailors much smarter than I (is it "me"?)
KevinMc
Mine is located in the port aft locker - upper part. When they were building my hull they must have been using a different guy. Probably the instructions were: "Install the compass in the locker back aft. Where? Anywhere you want."
markws1852
Mine is located along the bulkhead that separates the head from the saloon area on the port side (in the storage locker).
Mark Schlussel
C350 #300
Mark Schlussel
C350 #300
ok, You all passed the first part of the Take-home quiz (Leigh and I are old (well he is) professors, so can't help ourselves.
Question, where is the "junction box"? So far, i know where the compass is and the "computer". I say computer since it is where one attaches the various instruments.
Maybe a loose wire is located in the junction box.
ps. no cheating, you are on the honor system. The Forum has also taken over everyone's computer and is monitoring its usage. So......
Dave,
Please be more specific about the "junction box" Is it for the autopilot flux gate compass?
Mine is wired directly into the instrument head with no junction box for wire splices. I have traced it through the steering pedestal directly to the flux gate head.
i don't know of any other junction boxes in the system.
markws1852
Mine is mounted behind the wood instrument panel above the nav station. There are four mounting screws that hold the panel in place. I've changed out the computer twice--once when upgrading to the latest autopilot and previous to that when sending the unit to Raymarine for service.
Mark Schlussel
Legal Tender III #300
Mark Schlussel
FLCaptBill
- Contact:
Mark - Which autopilot did you upgrade to? Was it a Raymarine product?markws1852 wrote: Fri Feb 17, 2017 6:49 am Mine is mounted behind the wood instrument panel above the nav station. There are four mounting screws that hold the panel in place. I've changed out the computer twice--once when upgrading to the latest autopilot and previous to that when sending the unit to Raymarine for service.
Mark Schlussel
