Does anyone have the cross referenced part numbers for FRAM, NAPA, Gates, etc. for the following Universal 35B part numbers?
v-belt: 030475
fuel filter: 298854
oil filter: 036918
or the impeller kit: 200175
filter and belt, cross-reference numbers
davidjohnson708
David,
The following info was "borrowed" from the C34 web page:
Oil Filters
Universal 300309 or 209
Purolator PER-4620
Kubota 70000-15241
Fram PH-3593-A (replaces PH 2849A)
Motorcraft FL-799
AC PF-57
Lee LF-2808
NAPA 1064
Baldwin B179
Wix 51064
Diesel Filters
Universal 298854
Car Quest-86390
Kubota 70000-43081
Wix 33390
NAPA 3390
AC TP807
Purolator PER-262-F
Motorcraft FG72
Fram P-7514
Big-A 538
FAN BELTS:
Gates 7410
Dayco 15410
Goodyear 13411
FLAG 41013
OLD NAPA Rayco TOPCOG1540S 1141030 2694:8
OIL:
10w40, Diesel Oil CF or CF-4 or CG-4………….do not use obsolete S, CD or CE
I'm not sure about the Universal/Sherwood impeller. Maybe someone else can comment.
Hope this helps.
Oil Filters
Purolator PER-4620
Kubota 70000-15241
Motorcraft FL-799
AC PF-57
Lee LF-2808
NAPA 1064
Baldwin B179
Wix 51064
Diesel Filters
Universal 298854
Car Quest-86390
Kubota 70000-43081
Wix 33390
NAPA 3390
AC TP807
Purolator PER-262-F
Motorcraft FG72
Fram P-7514
Big-A 538
FAN BELTS:
Gates 7410
Dayco 15410
Goodyear 13411
FLAG 41013
OIL:
Hope this helps.
C350ia
Re: filter and belt, cross-reference numbers
Has anyone ever had any issues with using non-OEM filters?
Never had a problem over 25 years. To quote an old commercial "Motor oil is motor oil".C350ia wrote:Has anyone ever had any issues with using non-OEM filters?
