I have purchased an installed - port side adjacent to boarding ladder (Hull #265)
It works well however, have not been able to use it while the bimini is up. Some postings had indicated they had been able to use it with bimini.
Any suggestions?
Thanks in advance
Garhauer Outboard Motor Hoist
- Contact:
Re: Garhauer Outboard Motor Hoist
I mounted mine on the port side of the stern.
The Garhauer lift has two positions, one is "up" about 45 degrees, the other is a straight 90 degree. The 90 might make your lift low enough to clear the Bimini? Mine is mounted outboard of the engine rest.
