I am seeking to find out if anyone has had experience of their drive belt being ground into fine rubber powder and why. My yacht (Avalon, ex Kuchina) has a Balmar 100A alternator and runs the normal M35 3/8" belt and has done hundreds of hours with no problem.
Recently two things have been happening, firstly, the raw water pump has developed a slight leak (about to change it over, replaced seals once and still leaks at the weep hole) and the weep hole is above the alternator belt, so that the occasional drops of salt water drip onto the belt and run down the belt to the drive pulley. I have used wet and dry on the pulley to remove obvious surface rust but it is now slightly pitted.
Secondly, the drive belt started to put ground rubber all over the alternator and engine surrounds so I figured the belt was failing and replaced it after cleaning up the whole front of the engine and sump. To my dismay the new belt (correct size) immediately started creating rubber dust as well.
I am confident it is not an alignment problem as I have done over 500 hours with everything where it currently is and no problem. So I am attributing the ground rubber to the pitting on the pulley faces of the drive pulley and thinking I now need to get a replacement pulley and change over.
Any comment about, or experience of this very welcome.
Cheers
Russ Peel Avalon Hull #150
