Has anyone dropped their oil pan. When i run my engine 8-10 hours straight i had some slight oil leakage around the seal between the oil pan and engine block. None at lower levels of operation prior, although i have not run it much since taking it down the ICW.
The M-35's do not have gaskets, but use a copper sealant. My engine still is under warranty. I have 232 hours on the engine.
Allsail
Oil Pan
johnny canuck
I had the same problem with my M35B on my C34 MkII. Do not tolerate any oil leaks while you have a warranty. If the selling boat dealer is uncooperative, contact your local Universal dealer. This is a big job as the engine has to be raised for screw removal and the oil pan recaulked with the copper permatex. As well, keep an eye on the gasket for the raw water pump. FYI, you will have to cut about a 1/4" off the HX zinc. The OEM pencil zinc is too long and will break when screwed in to the Hx!
Richard Ad
Re: Oil Pan
Hello Allsail: can you share what happened with your oil pan? I ran for 6 hours and another 6 hours the next day and found approx 5 ounces of oil in my engine well. Did you have to have work done to your engine to remediate the problem? I'd really like to hear what you did? Thanks. Did anyone else have this issue?
Allsail
Re: Oil Pan
Richard,
I would make sure your raw water pump/gasket is not the culprit, first.
I did not suspect my RWP until a mech indicated that could have been the problem.
I had to replace 3 of the Sherwood pumps before i got one to hold up and i only have 300 hrs on my engine. Others have had issues with the Sherwood's prematurely leaking water , also.
I haven't heard much about them recently so maybe a bad run of them is over.
I have not had any further oil issues but have not had to run the engine as hard as when i found the small amount of oil. That said, i do not think it was the oil pan and was most likely the RWP.
Allen
Allen
Stu Jackson
Re: Oil Pan
You could replace the Sherwood with an Oberdorfer. The C36 folks just provided a great writeup about the replacement. See our C34 Tech wiki for the details: http://c34.org/bbs/index.php/topic,5880.0.html
