Interior Stain
zman18
Interior Stain
Post by zman18 »
Has anyone done any touch up on there interior stairs, if so what type of stain did you use? Thanks
John Zoda
Compass Rose
Hull# 484
Re: Interior Stain
Unless you are going to strip and start from scratch (in which case you can use any varnish you want, including oil based which are better for that wet environment), check with Warren Pandy at Catalina for what was used on your hull number.
