Shower Drain Pump
Posted: Tue Apr 08, 2014 3:40 pm
I’m having problems with the shower drain pump and wanted to see if anyone had any thoughts. This has not been right since we bought the boat used a few months ago. The previous owners never used the shower so it sat for 6 years with no use, which is most likely the root cause of the problems.
Now when used the water would pump out then flow back into the shower area. I thought this was caused by a problem with the vented loop and got a new one today. After installing it everything appeared to work fine for a while, then:
The float switch stopped turning off the pump. Also the pump will sometimes pump out the water and other times run but not pump any water. Appreciate any suggestions. Thanks
