Setting Idle Speed
Posted: Fri Jan 13, 2006 10:59 am
Came across this bulletin from Westerbeke - Manufacturer of our M35B engine
http://www3.telus.net/Atomic_4_Eng_Serv ... ttings.htm
BULLETIN NUMBER: 7
DATE: 2004
MODEL: New Universal Diesel Engines: M3-20B, M25-XPB, M35B, M40B, M50B
SUBJECT: Idle RPM Settings to Prevent "Damper Chatter"
New Universal diesel engines have an idle specification range of 200 rpm... ie 3 cylinder engines 1,000 - 1,200 rpm / 4 cylinder engines 800 - 1,000 rpm. In most cases the idle should be adjusted to the highest spec... ie 1,200 for 3 cylinder engines and 1,000 for 4 cylinder engines, in order to ensure there is no flywheel drive damper disc "damper chatter" when the engine is run in gear with the throttle set at idle. Damper chatter gradually damages the drive damper disc springs and the marine gear splined input shaft and forward/reverse clutches.
Because idle rpm in gear is related to propeller size, even with the idle speed adjustment set to the highest rpm specification the engine should still be checked for damper chatter by engaging forward gear with the boat tied to the dock and the throttle lever pulled back against the idle stop so the engine is idling at its lowest rpm setting. If damper chatter is occurring it will be heard as a faint metallic clicking noise coming from the flywheel housing which stops when the engine rpm is raised slightly. It may be easier to hear if one end of a piece of wood (ie a section of broom handle) is held against the flywheel housing and the other end is held close to the ear (AKA a mechanic's stethoscope).
Note: The actual engine idle rpm should be determined using a portable mechanic's tachometer held against the middle of the front crankshaft pulley, not the control panel tachometer (control panel tachometers are not accurate enough to be used for testing and / or adjusting the engine governor idle and maximum speed rpm stops because they usually are not accurate at all rpm even after being calibrated / adjusted at one specific point - which is usually maximum rpm or normal cruise rpm).
BULLETIN NUMBER: 7
DATE: 2004
