Green stuff from water leaks?
Posted: Tue Jan 18, 2022 2:28 pm
by jrohrbaugh
I am getting set for a haul out and in advance of my trip to the Abaco Islands in April. I've been off the boat for some time and when I started to work on clean up I found all these green corrosion telltales. Looks like slow leaks over time. Around water pump and Heat Exchanger ends and fittings.
Any suggestions?
Thanks again,
Jamie
S/V Soixante Hull #444
Re: Green stuff from water leaks?
Posted: Tue Jan 18, 2022 11:01 pm
by Chips Ahoy!
There are rubber o-ring gaskets on each side of the heat exchanger. Time to replace them!
Also, a good opportunity to clear out the exchanger ports.
Posted: Sat Jan 22, 2022 10:28 am
by jrohrbaugh
I've ordered the replacement gaskets and the new covers, etc. Let's see if that fixes the problem.
Thanks for the reply
Posted: Sat Jan 22, 2022 10:56 am
Jamie,
Electrolysis substantially increases the corrosion/oxidation.
Check for both AC and DC current-- one probe on the engine component, the other on something in the water. Just dangle one end of a wire (strip an inch or so) in the water and bring the other end to the engine so you can use your meter there.
