Alternator
Alternator
Does anyone know if the stock alternator has a regulator has a Temp sensor which adjusts amperage to control temperature (overheat).
Re: Alternator
Have you tried doing a web-search for the make and model of alternator. Should be mentioned if it has that feature. If not, contact the alternator manufacturer (will not be the engine or boat manufacturer).
