I removed the wobbly base plate that was mounted under the head. It had failed, allowing the head to be unstable. It was a very easy fix. Remove the screws, mark and drill three holes, insert and tighten the lag bolts. No more nosie than befor-you never were able to discreetly flush and still will not be able too, but it is now rock steady.
Sam
LONGHAWK #173
head base plate
- Jack McDonald
More info please
Sam,
Did you have to disconnect the hoses and remove the head in order to do this fix?
Jack
Friendship
C350, #80
Chesapeake Bay
Friendship
C350, #80
Chesapeake Bay
head baseplate
I did not have to remove the hoses. I was able to unbolt the unit from the baseplate and lift it up about six inches. I used a few books wrapped in a plastic bag to hold the toilet up. I then was able to remove the plate. I then lowered the toilet and marked the holes. then re-lifted the toilet, drilled, then lowered and installed. All in all about a thirty minute job.
Solid is good!
Solid is good!
