head base plate
Posted: Mon Jul 10, 2006 7:18 am
by LONGHAWK
I removed the wobbly base plate that was mounted under the head. It had failed, allowing the head to be unstable. It was a very easy fix. Remove the screws, mark and drill three holes, insert and tighten the lag bolts. No more nosie than befor-you never were able to discreetly flush and still will not be able too, but it is now rock steady.
Sam
LONGHAWK #173
More info please
Posted: Sun Jul 23, 2006 9:10 am
by Jack McDonald
Sam,
Did you have to disconnect the hoses and remove the head in order to do this fix?
head baseplate
Posted: Wed Jul 26, 2006 5:35 pm
by LONGHAWK
I did not have to remove the hoses. I was able to unbolt the unit from the baseplate and lift it up about six inches. I used a few books wrapped in a plastic bag to hold the toilet up. I then was able to remove the plate. I then lowered the toilet and marked the holes. then re-lifted the toilet, drilled, then lowered and installed. All in all about a thirty minute job.
Solid is good!
