Motor Mount brand
Air Mobility
Motor Mount brand
Post by Air Mobility »
I’m getting a good deal of vibration up to 1100 rpm. I’m going to calibrate the tack and recheck the motor mounts for integrity first, but I might have to replace the motor mounts. I have about 1800 hours on the engine (hull 158). I’m looking for the manufacturer of the original motor mounts. Does anyone know?
George Fisher
SV Air Mobility
Hull 158
Re: Motor Mount brand
Has the damper plate ever been replaced? If not you may want to read the posts in this forum regarding replacing the damper plate. I found that was the source of our low speed vibration.
Air Mobility
I changed the damper plate 2 yes ago.
George Fisher
SV Air Mobility
Hull158
