belt
Posted: Sun Apr 14, 2019 9:32 pm
by hperros
The Westerbeke belt on my Universal 35B disintegrated after about 100 hours. The new one I got, same part # 30476, fits okay but it is a little shorter by about 1/2 inch. Are there two sizes ???? I can't imagine that the belt stretched.
Also, does anybody know what size auto belt I can use instead?? From previous experience on another boat and engine, they last longer.
Re: belt
Posted: Mon Apr 15, 2019 7:56 am
Where is the adjustment bolt (alternator) in the slot. Said another way, can it be properly adjusted and still leave room for adjustment as the belt stretches?
The other issue (other than length) is that it properly fits in the groove.
Re: belt
Posted: Mon Apr 15, 2019 12:42 pm
by hperros
Yes, the bolt in the bracket has about 1/2 an inch to go further out.
Harr
Re: belt
Posted: Mon Apr 15, 2019 2:25 pm
Taking your two posts:In the first you mention that the new belt is SHORTER than the old one. In your second post you say you only have an additional 1/2" of adjustment left in the alternator adjustment slot.
Conclusion: You DEFINITELY don't want a longer belt!
Again, verify the other criteria-- that the belt fits properly in the "V's", neither bottoming out in any of the pulleys nor so wide that it only contacts the upper part of the pulleys.
Re: belt
Posted: Wed Apr 17, 2019 7:33 pm
by hperros
Thanks, I will take a look how the belt sits in the pulley.
Harry
Re: belt
Posted: Mon Oct 05, 2020 6:45 pm
by Miss Adventure
I believe the belt is a 29.5 inch xo. If you go to the westerbeke web site they show the info on the belt.
Re: belt
Posted: Tue Oct 06, 2020 8:34 am
I use Gates PN 7395. But given your 2 posts I suspect you have the correct belt. When new, my adjustment is about in the middle of the slot, as it ages, adjustment slot is nearly used up. My experience is that they last about 7 years (1000 hours).
