Upgrade to High output alternator
sargentef
Re: Upgrade to High output alternator
Post by sargentef »
Thanks "Fat Cat" for the clarification.
"Seawing"
Hull# 309 2005
JohnNorton
Post by JohnNorton »
In so. Cal. we have two 100 w solar panels, flexiable type, which we attach to the bimini during our trips. We just replaced our 55 amp Mando with another identical 55 amp (such an easy job!).
The two solar panels replace enough amps (150+- each day) we don't need to start engine for recharging. We have LED lighting and are careful with refrigerator (turn thermostat to high setting,nearly off at night).
rickkremel
Post by rickkremel »
Hi Leigh, could you tell me the model number and anything lease needed to order a spare alternator?
Thanks so much.
Rick,
I used an older GM 2" foot 150 Amp, 3 wire external regulator alternator found on ebay for about $120. Used a ARS4 smart regulator. Had to modify the tensioning bracket and changed the belt to a serpentine with new grooved pullies on the crank, water pump and alternator. This conversion kit was from Beta Marine. (about $250) a few years ago. Let me know if that helps.
