Leak on port side seems to come from where deck liner meets
Posted: Fri Jan 27, 2017 6:34 pm
I am finding moistureon the port side from the head compartment to about halfway through the cabin. Upon removing things the moisture seems to be coming in where the deckliner separates from the deck forming recesses for wiring etc. The stanchion bases and holding tank waste deck fitting all seem fine, and water is well above the hull deck joint, in fact the underside of the deck is damp all along this area. I am wondering if the forward hatch or hatch in the head is possibly leaking (no obvious signs or dampness that can be seen) at the joint with the deck and then running between the solid part of the deck and small voids in the headliner. I don't think this water is coming from the windlass or anchor roller as those areas are dry. Anyone else have water mysteriously show up like this and if so did you find the source?
