overheating at idle after fresh water pump install
Posted: Sat Sep 24, 2016 7:23 pm
The engine had been overheating at 2300rpm or above for a couple years. The HX was cleaned and tested last year. Just replaced the fresh water pump a couple hours ago, along with 3 of the small hoses around it. Tried to drain as much coolant as possible by opening petcock at bottom of HX too, so I could start with fresh as possible coolant.
Filled with anti-freeze, started engine for a few minutes, refilled with coolant. Started again and it overheated, at 200 degrees, after 5-10 minutes. Water was flowing from the exhaust.
I'm guessing air lock, but I don't know how to purge it. I did open the petcock at the top of the cooling system while it was running, but no liquid came out.
What is the procedure to purge air from the system?
