Turn on Matrix DC Battery Meter
Posted: Thu Sep 22, 2016 8:27 pm
by MikeDH
I recently purchased a 2008 Catalina 350 MKII. My first boat and I'm really enjoying it. But I can't figure out how to get the DC battery meter to turn on. The owner's manual says the intro screen will stay on for five seconds after power is supplied to the meter, then the readings will be available. This is probably a newbie question, but how do I get power to the meter? Any advice is greatly appreciated.
Re: Turn on Matrix DC Battery Meter
Posted: Fri Sep 23, 2016 6:35 am
Mike, congratulations on the new boat and welcome.
I'm not familiar with your monitor but I did find this info -
http://webserver.flak.no/vbilder/10128.pdf The schematic on pg 6 shows an isolator switch. Perhaps the previous owner used a breaker for this function. Turn on all your breakers and see if the unit powers up. If that doesn't work, get in touch with BEP Marine and see if they can help.
Posted: Fri Sep 23, 2016 9:16 am
by MikeDH
Thanks Ken. So the monitor should always be on assuming the previous owner didn't connect it to a breaker?
Posted: Sat Sep 24, 2016 6:03 am
It appears that the unit is wired directly to the batteries being monitored. It would be strange to have an "always on" instrument, but unless there is a separate switch (isolator switch shown in schematic) or a breaker is being used, I don't see any other way to power on/off the unit. Note also that there are 1 amp fuses on the positive lead between the monitor and each battery. Be sure to check those as well.
Posted: Thu Oct 06, 2016 1:02 am
by MikeDH
Update - It turns out the wire connector somehow was inserted incorrectly into the socket in the back of the monitor. Once inserted correctly, it is now working again. Ken- Thanks again for your suggestions.
