My autopilot has ceased to function. Checked the rudder angle sensor which checked good. Haven't yet checked the power to the clutch and motor of the linear drive, but when I engage the pilot I can hear the motor in the drive and while watching the drive ram there is no movement. Same with pressing -+10. Since I can hear the motor, I'll assume it's getting power, but I'll check it while I'm checking the clutch power.
Has anyone actually had a linear drive go bad? If mine is kaput I plan on taking it apart to see if it's user serviceable. I did see one YouTube vid when a guy took his apart and put it back together, doesn't seem too daunting.
I do hope it's the drive and not the computer, which I hear are quite pricey. I'm assuming we have the series 1 linear drive in our boats, which makes sense ,based on the weight.
Any comments or suggestions are welcome. Will let you know how it turns out.
Autohelm "Drive Stopped"
Ed Kruzel
S/V Emily
Hull #399, 2006 C350
Cataumet, MA
S/V Emily
Cataumet, MA
Re: Autohelm "Drive Stopped"
Ed,
We just bought Hull 167. My Surveyor recommended installing a Rudder Stop to prevent the RAM from reaching the end of it's mechanical travel and putting pressure on the RAM seals. I haven't climbed down to get a closer look yet. Not sure, but if the RAM is leaking it should be obvious.
Regards,
Bob Baker
Cat350-Free Energy
Regards,
Bob Baker
Cat350-Free Energy
Thanks for the suggestion. My drive is not hydraulic, strictly mechanical.RFBaker167 wrote:Ed,
Regards,
Bob Baker
Cat350-Free Energy
I found the problem to be a broken wire between the course computer and the clutch. So even though I could hear the drive motor working, the clutch wasn't engaging, so no arm movement.
Fixed the break and all is well.
Ed Kruzel
S/V Emily
Cataumet, MA
S/V Emily
Cataumet, MA
