Hi Guys,
My freezer thermostat (Analog Knob Type) has failed on the freezer side of the Adler/Barbour ColdMachine.
On the top of the thermostat, the part number is labeled as C1712JR680. The schematic lists the range control of the thermostat as C1502JR.
I'm having a hard time finding a replacement. I want to stay with the analog version versus the digital version.
Does anyone have a source with a part number and price?
2004 C350
Freezer Thermostat
Freezer Thermostat
Re: Freezer Thermostat
Hello Bill, just seeing your post. I have the same analog thermostat as you do and purchased an exact replacement from Fisheries Supply. The part is
Item ID: DOM F1710 and was $149.48 (free shipping). Their number is 206-632-4462 and they are on PDT.
Hope you're successful.
Cheers, Jim
Cheers, Jim
Jim Lassiter
Hi Jim,
Thanks for getting back with me!
Unfortunately, they are out of stock and are now asking $180.
I'm hoping someone has found and installed a 3rd party substitute.
C350
C350
Go2Marine has this info on web site and carries both the refer and freezer models. I just replaced the refer one at about $43.00. https://www.go2marine.com/Product-Guide ... _02_12.pdf I recommend this source.
Steve Montgomery
Salty, hull #418
Deltaville, VA
Salty, hull #418
Deltaville, VA
Hi Steve,
I recently purchased this one from Defender; https://defender.com/en_us/adler-barbou ... at-4060204
I plan to install it this w/e. I'll report back if it works.
If it doesn't work, I'll try the one you referenced from Go2Marine.
Thanks!
2004 C350
#193
Thanks!
2004 C350
#193
