HELP HELP ROUTING WIRE AND A/C COOLING LINE
stevewitt1
Post by stevewitt1 »
cker) and stern (transom) so to be practical I had to put the second 30 amp access at both bow and stern. Great, another $75 for the receptacle and another $95 for a second breaker within 3' of each one.
Now for the question:
I have to run a 12/2 w ground to the lazarette for the power supply and the water supply from the bilge area to the lazarette. I also want to run another 12/2 or 12/3 w grounds to the galley area to put some of the load {micro, coffee maker, toaster, ice maker} to the second power supply.
I can't find a good path from behind the AC panels on the port side over to the starboard side, preferably inside the lazarette.
HELP HELP HELP
Steve
Oconto Yacht Club on The Green Bay
Of Lake Michigan
www.ocontoyachtclub.com
