Hello all,
Can anyone tell me where to access the onboard side of the 2 small thru hulls on the starboard side rear quarter? Mine need to be replaced. Also, are they both 3/4 inch?
Ed
2 small thru hulls on Starboard side of hull
Ed Kleinstuber
s/v Starfish
C350 #333
s/v Starfish
C350 #333
Re: 2 small thru hulls on Starboard side of hull
I have replaced the two 3/4" drains from inside the bottom of the starboard cockpit locker ( tight fit) and some what hard to swing a tool to take them out. The replacements are SS and wont suffer the sun degradation that the originals had. Found the SS fittings on Ebay. I also replaced the anchor well drain with a SS unit as well. Clean out the locker and have fun squirming!!!! Having smaller and younger friends is a big help.
Good luck.
Good luck.
Thanks very much, Leigh. Can you tell me how long they are? Would like to get them ordered before fighting the removal battle.
Ed
Ed
Ed Kleinstuber
s/v Starfish
C350 #333
s/v Starfish
C350 #333
As I recall, the hull and backing block was about 1" thick plus allow for the threads of the fitting your are looking at about 2" . I don't recall if I trimmed the length to install. The 1-1/2" anchor well drain, once removed gave the dimensions. You have more room for the install in the front.
Have fun.
Have fun.
