Anybody have a source for the Al extrusion for the rub rail?
Thanks.
Rub Rail Aluminum
Rub Rail Aluminum
vr
Bob Engelhart
SV Andiamo #464
Punta Gorda, FL
Bob Engelhart
SV Andiamo #464
Punta Gorda, FL
Re: Rub Rail Aluminum
Bob, I suspect your best bet is to call Catalina parts department.
I have a complete rub rail Al. extrusion replacement for my 2004 350 which I never installed. The Catalina 350 used two sizes of rub rail. This replacement is the current size which does not fit the old rubber insert. Slight width change. If you need it I will part with it as I don't think I will get around to installing it.
It is in several sections and was shipped to me motor freight from Catalina Direct It is located in Southern New Jersey and can be picked up from NJ or I can move it to Georgetownn Md. I will check for the bill from Catalina but will take a reasonable offer plus shipping.
If you are close to my location please arrange to stop by and check it out. Send me a PM for the address and pix's if you like
Leigh
Leigh
