My current Sherwood G908 pump is failing on my M35B and I'm looking to replace it. I've read some conflicting stories about replacing it with the Oberdorfer N202M-908. Some articles say this is a direct replacement while others indicate that some modification may be required. Also another article talked about folks seeing steam in the overboard discharge because the flow rate of the Oberdorfer is not as much as the Sherwood. Appreciate any feedback on this topic.
John
Hull #484
Raw Water Pump Replacement
John Zoda
Compass Rose
Hull# 484
Compass Rose
Hull# 484
Re: Raw Water Pump Replacement
I did the same replacement, and found this information on the Catalina Direct site and the linked article to be very helpful: https://www.catalinadirect.com/index.cf ... ngines.cfm
