Fuel Sender
Fuel Sender
Just replaced my fuel sending unit. It was very easy. The part came from Moller Marine Products and the number is 035762-10.
Re: Fuel Sender
When replacing the unit did you have difficulty removing the gaskets? Did you place the gaskets dry or put a sealant on the gaskets. What length sending unit did you use? Thank you. John
Re: Fuel Sender
The unit I installed is 11 inches long. I had no problem getting the gasket off and I mounted it dry.
