I discovered the overboard discharge valve was cracked after the winter. It has a read handle and is below the sanitary tank in the head. The schematic from the Catalina 350 Owner’s Manual that lists the valve as a Spears PVC compact sealed ball valve and it looks to me as though it is the 1 1/2 inch type B model. However, the Spears website (www.spearsmfg.com) suggests that there is more than one valve B. For example there are threaded and socket types and I’m not sure how the valve is attached to the bottom of the tank. Any recommendations for a replacement part?
Daniel Brodsky
Toronto, Ontario
Holo Nui, Hull #354
Overboard Discharge Valve
Dan Brodsky
Toronto, ON
Holo Nui - #354
Toronto, ON
Holo Nui - #354
