Dorades
LONGHAWK
Dorades
Post by LONGHAWK »
Has anyone installed (or seen a setup that would work) dorades on the 350? The only function that I found that I need that I have not found a good solution for is air movement in hot / inclement weather or offshore in bad weather.
I am asking the all-knowing list for ideas.
LONGHAWK #173
Dorades
Post by Triumph »
I have installed two of the solar vents on the two hatches over the main cabin. They are the larger, stainless ones, and I put them in the center of the plexiglas hatches. I have the 4 3/4" hole saw if you decide to go this way.
I figured this was best to suck the hot air out of the boat, and avoid water coming in like might happen if i had put one in the front hatch. They are up high, and not likely to get doused.
jonnjones
Re: Dorades
Post by jonnjones »
This is a pretty old thread, but I'd like to repeat the question. Anyone install Dorades or any other ventilation upgrades?
Jon and Lori Jones
S/V Wind Orchid
Annapolis
Hull #273
