Hello:
I am planning on installing four fans in my boat -- two in salon and one in each berth. It doesn't appear there is any pre-wiring for fans. Looking for suggestions regarding the best plan for installation.
Best path/technique for getting wiring to starboard side? Any other suggestions/tricks/words of wisdom will be greatly appreciated.
Dan Dirkse
Alibi #262
Installing Cabin Fans
Re: Installing Cabin Fans
Dan,
Assuming you use quality, low amp draw 12 VDC fans such as those offered by Hella (http://www.hellamarine.com/en/products/ ... o-fan.html you can just tap into the wiring for the lights.
